        Custom Toolpath
Hello All,
I was wondering if there is a way to manually design the Infill structure, the walls and the horizontal solid layers separately, instead of the slicer taking a solid box and generating these different layers automatically. I generally exp0rt ge0metry from Rhinoceros. Perhaps there there are ways to customize the toolpath. For example, I could have curves on separate layers for infill, walls and floors, and it translates in different speeds for the Gcode. Thank you all in advance.
R
                            Napsal : 03/06/2022 2:31 am
                    Simply incorporate the internal structure in your original design and then slice with 0% infill
                            Napsal : 05/06/2022 4:29 pm
                    In a simple shape like your examples above a simple modifier would allow you to make those changes.
                            Napsal : 06/06/2022 4:05 pm
                    1 lidem se líbí
