Can I/How Do I Make a Plastic Punch?
Razor
(@razor)
The screws in my aluminum screen door have stripped out. I have some oversized screws that I’m going to use but the screw holes and the area around them got a little bent up. For a little engineering project I was thing about having my son make a block/flat punch to smooth things out and the bracket sits flat.
I have tons of PLA, PETG, ABS, and ASA. Problem with the latter filaments is I don’t have an enclosure for the Mini+ yet so I was going to try and stay away from them. Although part of me thinks that I could probably considering considering how the print is going to be used. 😏
Does anyone have suggestions as to how many walls I should use and what the infill should be? Thanks!
Best Answer by Diem:
For this job it would be much better to cut a wooden form.  All of your filaments would shatter under the hammer.
Mini+MK3S+XL 5 Tool
Opublikowany : 06/09/2022 11:33 pm
Opublikowany : 07/09/2022 12:37 am
1 ludzie polubili
Razor
(@razor)
RE: Can I/How Do I Make a Plastic Punch?
Kind of what I thought, but it didn’t hurt to ask. Thanks!
Mini+MK3S+XL 5 Tool
Opublikowany : 07/09/2022 3:56 am
