Multicolor (same layer) print with standard mk2
cyrille.p
(@cyrille-p)
Hi, I've tested a new way to print multicolor objects with different colors on the same layer. The result is awesome:
I explain how I do it on the video. It's in french but I think you can understand just by looking at it. I'm using slic3r PE 1.37.1
If you want to test it, you can download the keychain here https://www.thingiverse.com/thing:2594294
My youtube channel about the Prusa I3 MK2 https://www.youtube.com/channel/UCz-zQZcKcvEDdd9C9hOKYWg
Postato : 21/10/2017 7:33 am
JeffJordan
(@jeffjordan)
Utenti Moderator
Re: Multicolor (same layer) print with standard mk2
💡 so you are simply doing what the mm-kit does manually, by using the M600 command inside a layer.
this is a good option/idea when using colored effects at flat surfaces.... but I won't recommend it when the change of color(s) is needed every layer 🙄 .
Postato : 22/10/2017 11:40 am
kevin.r5
(@kevin-r5)
Some discussion and links to instructional videos of this technique here:
https://shop.prusa3d.com/forum/print-tips-slic3r-settings-kisslicer-model-repair--f12/multi-color-printing-different-way-t4836.html
I've accomplished the same thing using simplify3d and multiple processes.
-Kevin
Postato : 22/10/2017 7:52 pm
