Covid headband seam issue
Johno
(@johno-2)
Hello , I am printing headbands for shields quadro and double, using Simplify 3D, but after slicing and printing , there is a seam in the middle of the part which is touching forehead. This is appearing only in the middle, like there would be a tube modeled inside if the middle part. Any idea how to avoid this?
Yes I know it is not appearing if I use other slicer, but there has to be something which could help in Simplify as well.
 Thanks for your advice.
Jan
Publié : 21/04/2020 9:08 am
RE: Covid headband seam issue
Posted by: @hdolezel
Jan
In PS the seampositions you can modify here:
with aligned you usually get good results.
S3D look here: https://forum.simplify3d.com/download/file.php?id=1057&mode=view
Publié : 21/04/2020 10:08 am
Johno
(@johno-2)
@karl-herbert
Thank you for your reply, but I think that is not the issue. I have found, that there is something like small tube modeled inside the stacked Covid headbands, PS is taking that as a one solid bit, but S3D is finding the tube and slicing that as well.
And that is causing the seam exactly in the middle of the headband.
Ce message a été modifié il y a 6 years par Johno
Publié : 22/04/2020 12:50 pm
