Covid headband seam issue
Johno
(@johno-2)
Hello , I am printing headbands for shields quadro and double, using Simplify 3D, but after slicing and printing , there is a seam in the middle of the part which is touching forehead. This is appearing only in the middle, like there would be a tube modeled inside if the middle part. Any idea how to avoid this?
Yes I know it is not appearing if I use other slicer, but there has to be something which could help in Simplify as well.
 Thanks for your advice.
Jan
Posted : 21/04/2020 9:08 am
RE: Covid headband seam issue
Posted by: @hdolezel
Jan
In PS the seampositions you can modify here:
with aligned you usually get good results.
S3D look here: https://forum.simplify3d.com/download/file.php?id=1057&mode=view
Posted : 21/04/2020 10:08 am
Johno
(@johno-2)
@karl-herbert
Thank you for your reply, but I think that is not the issue. I have found, that there is something like small tube modeled inside the stacked Covid headbands, PS is taking that as a one solid bit, but S3D is finding the tube and slicing that as well.
And that is causing the seam exactly in the middle of the headband.
This post was modified 6 years ago by Johno
Posted : 22/04/2020 12:50 pm
