start prusaconnect withput serialnumber or get new serial number?
lucas.l
(@lucas-l)
I wanted to add my old MK2.5S to prusaconnect. I updated it quite alot and also had to replace the Rambo Mini 1.3a Board a while ago.
When i connect this printer, prusa connect tells me, it is not able to automatically find the SNR, i should just type it in. But i do not know the original Serial Number. Is there any way to start without SNR or to get a new one? Right now i am not able to use this printer with prusa connect..
Posted : 09/11/2022 3:22 pm
Tojik
(@tojik)
Member Moderator
RE: start prusaconnect withput serialnumber or get new serial number?
Hi, what version of PrusaLink are you running? 0.7.0 RC1 should be able to pull the serial number off of the USB chip and so allow you to use it without much troubleshooting. The other way would be to get the printer's serial number from the USB driver yourself. But I know only the Linux way.
Posted : 09/11/2022 3:28 pm
lucas.l
(@lucas-l)
thank you for you fast response. i am using latest (0.7.0 RC1)
Posted : 09/11/2022 3:29 pm
Tojik
(@tojik)
Member Moderator
Oh, that's worse. Sorry, don't know the proper way to give you one, so please contact customer support and tell them what situation you're in. Prepare your order numbers, they'll probably want some.
Posted : 09/11/2022 3:34 pm
lucas.l
(@lucas-l)
is there no way to get it working without SNR? i do not have any order number since it is very old one and upgrade many times...
Posted : 09/11/2022 3:38 pm
Tojik
(@tojik)
Member Moderator
you almost certainly have one. They get stored into your prusa account and are sent via email
Posted : 09/11/2022 3:41 pm
lucas.l
(@lucas-l)
if you know how to manually get the snr out of the usb i can try that, linux is fine for me. but i think there is no snr, because i had to replace the rambo mini board and ordered directly from ultimachine (was not in stock at prusa shop that time).
Posted : 09/11/2022 9:41 pm
lucas.l
(@lucas-l)
any update on this? i tried talking to the support guys as you recommended. They tried to help, but were not able to. They pointed me to the hidden "experimental" menue to activate fake SNR, but this is only available on MK3. They wanted to check this internally and get back to my with a soultion via email, but i havent received anything.
Posted : 11/11/2022 8:42 am
Tojik
(@tojik)
Member Moderator
I cannot say more. The way your case should be handled is - support gets the order number from you and somebody figures out how to give you a new serial number. Then you'll use that. I'll ask about this when I get to Prague
Posted : 14/11/2022 7:19 pm
Tojik
(@tojik)
Member Moderator
To get the serial number in the board (if there is one), run
lsusb -v -d 2c99:
with the printer connected and turned on. The serial number should be on a line named iSerial
Posted : 15/11/2022 12:09 pm
Dali
 Dali
(@dali)
I tried using the "Fake serial number" option but it is still not populating this. Any suggestions?
root@mk3s:/home/pi# lsusb -v -d 2c99:
Bus 001 Device 005: ID 2c99:0002 Prusa Original Prusa i3 MK3Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 2 Communications bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 8 idVendor 0x2c99 Prusa idProduct 0x0002 bcdDevice 1.30 iManufacturer 1 Prusa Research (prusa3d.com) iProduct 2 Original Prusa i3 MK3 iSerial 3 bNumConfigurations 1
Posted : 12/09/2024 11:06 pm
Petos
(@petos-2)
I have the same issue. With the latest firmware 3.14 and prusa link tried the fake serial number function, but it does not create any SN. Do you have any solution how to use the prusa link with mk3s without a serial number. Thank you.
Posted : 25/09/2024 6:28 pm
