Serial number in PrusaConnect incorrect
I just got off the chat with Prusa support on an issue with my XL. They asked me for my serial number, so with my printer against a wall and the serial number on the back I thought, hey, let's just grab it from PrusaConnect. Alas, it turned out the serial number showing in PrusaConnect has no resemblance to the one on the printer's sticker ☹️
Opublikowany : 27/06/2023 7:10 pm
Hello
(@hello)
RE: Serial number in PrusaConnect incorrect
Id say wrong mother board put in wrong printer because the mother board store serial number
Opublikowany : 27/06/2023 7:19 pm
The serial number format showing in Prusa Connect is totally different from the format on the label so it's not simply a matter of a wrong number. The Prusa rep immediately said that's not a serial number.
Opublikowany : 27/06/2023 7:25 pm
Thanks for the heads up.  When mine arrives I will photograph the back before installing - it's going to be too heavy for casual manhandling.
Opublikowany : 27/06/2023 9:56 pm
Great idea! Most of the time I spent on the chat was me trying to get a phone behind the printer to take a picture of the serial number...
Opublikowany : 27/06/2023 10:41 pm
Hello
(@hello)
Is the one showing in prusa connect the api key?
Opublikowany : 27/06/2023 11:47 pm
No. The API key is further down on the page.
Opublikowany : 27/06/2023 11:51 pm
Tojik
(@tojik)
Member Moderator
Yep, they separated the printer S/N from the motherboard one. It's good because when you get a new mobo, the printer S/N stays the same. But yea, that means we cannot get the printer S/N easily
Opublikowany : 28/06/2023 11:14 am
That makes sense. But maybe the text in PrusaConnect should be changed to "Motherboard S/N", to keep others from being as confused as I was.
Opublikowany : 28/06/2023 11:22 am
