Prusa Connect: Stale data in Currently printing.
PaulCurtis
(@paulcurtis)
Membre
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4)
NA
PrusaLink versionPrinter typePrinter UUID (you can find it in Printer detail page - address line)
729449fd-a9ec-438a-901f-a3988c55fbd7
Printer firmware versionPrusaSlicer version (if applicable)Description of the bug, including steps to reproduce (if possible).
NA
PRUSA XL, Firmware up to date (6.4.0+11974).
I tried to print a long running print. Near the end of it the print warped and one end rose enough to cause a stuck filament error. I tried a few times to clear it but the nozzle kept hitting the print and the stock filament would come back again. Not able to do much else I aborted the print at the printer. I found myself at the home screen and powered off the machine from an external switch. Later I came back to the machine, powered it on and figured out just what happened. I decided to start the print again from the printers control panel. The prusa connect web page for my printer shows the new print, which still has about 26 hours left to it, will complete in 3 hours. It looks like it still thinks the old print is being printed.
Publié : 31/12/2025 7:20 pm
