Enhancements? and translation
Phil @PhilthyFilaments
(@phil-philthyfilaments)
Utenti
Pi Controls
Will there be options to control the Pi board itself.
  • Shutdown
  • Reboot
  • Restart PrusaLink
  • Change Hostname
  • Wifi Settings
  • Network Settings
  • DNS Check
  • Backup / Restore Settings
  • Backup / Restore Uploads (Gcode )
I currently only have one MK3S so I don't know...
  • Multiple Printers PER Pi Board?
How can one help with the Translation to another Language such as Japanese.
Postato : 30/12/2021 6:46 pm
G.design e Nox hanno apprezzato
cleo
 cleo
(@cleo)
Utenti
RE: Enhancements? and translation
I also support these enhancements. It is a problem for long-term OS stability to be constantly hard-powering off the embedded Pi Zero along with the printer and the current need to SSH into the Pi to shut it down from the command line is a big usability issue.
Postato : 02/01/2022 2:28 am
Matthew
(@matthew)
Utenti
Linux doesn't mind the hard power off, it's the SD cards that lose all of your data.  If you get "industrial" SD cards then you can safely power your pi off without the need to issue a shutdown command.  They can be a little tricky to get your hands on, but I was able to buy a small number of some Sandisk industrial 8GB cards on amazon through a reseller.  I'm running them in my prusalink Pi's.
Postato : 03/01/2022 4:33 am
G.design hanno apprezzato
Utenti
this isn't about the dataloss... sometimes, things require a reboot.
Postato : 05/01/2022 8:49 am
Matthew hanno apprezzato
