Cannot Login to PrusaConnect - "User Already Exists" JSON Error
[Solved] Cannot Login to PrusaConnect - "User Already Exists" JSON Error
rplanier
(@rplanier)
For at least the last 3 weeks or so, I have been receiving the below JSON error (instead of a typical HTML response) when attempting to login to the PrusaConnect service at https://connect.prusa3d.com.   It does not matter whether I clear cookies, use private browsing mode, or use a separate computer, I receive this error every time that I complete the account authentication process.  Is there a known issue with the authentication service for PrusaConnect?  Or is a reinstall of PrusaLink necessary to fix this issue?  Accessing PrusaLink directly via the web browser works perfectly fine.
I am running PrusaLink on a Raspberry Pi Zero W with API version 2.0.0, sever version 0.6.1, and version firmware 3.11.0-4955.  Printer is an i3 MK3S running firmware vesion 3.11.0-4955.
Thanks!
Best Answer by Jitka:
Hi, it seem that we have a bug in changing email functionality. Can you try it again?
This topic was modified před 4 years by rplanier
Napsal : 08/08/2022 11:59 pm
Tojik
(@tojik)
Member Moderator
RE: Cannot Login to PrusaConnect - "User Already Exists" JSON Error
Hi, sorry for that. Let me make sure I understand correctly. When you try to log in into Prusa Connect, regardless of the context (straight from the web, or PrusaLink wizard) It gives you this error. O do not remember, if you're supposed to log in or register the first time, but I assume you tried both. Thank you for clarifying, I'll forward this right away. Thank you for trying out PrusaConnect
Napsal : 09/08/2022 6:58 am
1 lidem se líbí
Jitka
(@jitka)
Napsal : 09/08/2022 10:49 am
1 lidem se líbí
rplanier
(@rplanier)
Jitka, that must have been it.  All seems to be working normally now when navigating to the PrusaConnect dashboard while logged in.  Thank you both for the quick responses!
Napsal : 09/08/2022 3:46 pm
1 lidem se líbí
