While printing normally, the operation always slows down at a fixed place and continues without filament output.
b-core
(@b-core)
hello.
As the title suggests, after pushing in the Z direction at a fixed place, the print continues without the filament being output. It recurs even after thorough bed cleaning and nozzle cleaning. It happens even if I adjust the Z level. Why.
Opublikowany : 15/09/2022 3:14 am
RE: While printing normally, the operation always slows down at a fixed place and continues without filament output.
I do not think there is enough information in this post.  If you are still having the issue, try to explain it more.
Opublikowany : 23/09/2022 11:36 am
b-core
(@b-core)
Hi cwbullet.
Please check back as we will upload the video.
Condition: octo print,PRUSA mini,PLA
Model X: Model where the phenomenon occurs
(1) Printing starts on a specific model X.
(2) Nozzle progresses in the +Z direction in the middle of the first layer print, causing heat bed interference (pressing).
(3) The nozzle moves in the -Z direction and printing continues without purging the filament.
◎Heat bed interference always occurs at a fixed position of the first layer.
◎Not occur when printing via USB by disconnecting the octo print
◎Not occur with other models.
Opublikowany : 26/09/2022 4:58 am
mark
 mark
(@mark)
What slicer version and what Mini firmware version do you have? You need the latest released firmware version to work with the latest slicer version. What version of Octoprint? If it works with the USB stick then there could be a bug in Octoprint or in the firmware that talks to Octoprint.
Regards,
Mark
This post was modified 4 years temu by mark
Opublikowany : 26/09/2022 9:51 pm
b-core
(@b-core)
Opublikowany : 07/10/2022 3:58 am
b-core
(@b-core)
Video upload
This post was modified 4 years temu by b-core
Opublikowany : 07/10/2022 4:10 am
