Superpinda upgrade - first layer problems
didier.l
(@didier-l-2)
To achieve a perfect first layer I've just upgraded my probe to a superpinda. Unfortunately, the new probe doesn't do anything for me, as the bed levelness (0.042mm max difference across the bed) is still an issue. I've also installed a silicone mod, but can't get rid of a low spot (pic attached), resulting in gaps responding to the low spot it seems. I was under the impression that the variance of my silicone mod is still far better than the original mountings and the superpinda would be able to do the rest in terms of mesh bed leveling. Also, I've noticed visible differences in the first layer (streaks). I've run the first test at 200/60, the second one at 210/60 (gaps are worese). Grateful for any tips or insights to achieve a (near) perfect layer!
PLA
200 Nozzle
160 Bed PLA
200 Nozzle
160 Bed PLA
210 Nozzle
160 Bed PLA
210 Nozzle
160 Bed PLA
200 Nozzle
160 Bed
Postato : 05/01/2024 2:15 pm
Tysonsw
(@tysonsw)
RE: Superpinda upgrade - first layer problems
0.042mm difference isn't a lot. The Mini can compensate for +-1mm.
How is your extruder gears teeth looking? I have had the same uneven extrusion issue when I noticed that it wasn't clean. Also might need to check that the gears in the extruder has a goog play and that the gear that sits on the motor is screwed in tight.
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: tysonsw@infosec.exchange
Postato : 30/01/2024 8:54 am
