Space prob
Bastien
(@bastien)
Space prob
Hello
I have a problem of print with my PrusaMini.
She print real good when the part is linear, but when is technic the object exit with many hole. See the picture. Can you help me please.
I have clean all printer, buse, and tight the motor extruder. https://photos.app.goo.gl/VkZH6xu8ubQ8hSLy6
Thank for the help.
Posted : 28/02/2025 10:31 pm
Your filament is wet.  This might not be the only problem.  Dry your filament and try again.  If problems continue, come back and show us new pictures.
Posted : 28/02/2025 11:46 pm
Bastien
(@bastien)
RE: Space prob
Hello,
No, i try new filament, and i try to do dry my new filament, lol.
I do that part for show you the problème.
I think is part of extruder but i have clean all the pet of my printer.
Tank for your hanswer
Posted : 02/03/2025 10:06 am
Maybe your dryer is not good?
Dry your filament.  Print again. Show us the result.
Posted : 02/03/2025 4:22 pm
Bastien
(@bastien)
RE: Space prob
Hello,
I have print with my Prusa Mini plus and my Bambou lab A1, and the result with the same filament. https://photos.app.goo.gl/JDNdRDuuDHUaj1Uv5
And you can see wave on the back of print. I was do the file gcode 3 time and she does the same print.
What do you think, can you help me?
Thank you.
Posted : 07/03/2025 9:10 am
Dry your filament between prints.
You may have a partial clog, try a cold-pull.
If you continue to have problems save your project as a .3mf file
Files > Save Project as
Posted : 07/03/2025 9:51 am
Bastien
(@bastien)
RE: Space prob
Hello,
I have a second problem with my Prusa,
When i want change the filament, i need to disasemble the base of extrudor for cut the filament and exit him.
Is this the nozzle the probleme?
Photo joint.
https://photos.app.goo.gl/RkvMrgAPtuqS6Dp29
Thank you
Posted : 09/03/2025 7:17 am
Check the pressure of the spring-loaded screw at step45 of:
https://help.prusa3d.com/guide/3-x-axis-extruder-assembly_199519#201258
Posted : 09/03/2025 9:34 am
Bastien
(@bastien)
RE: Space prob
After i have follow the step 45,
He is not better
https://photos.app.goo.gl/hWdyJofEcJsux7Dc6
Posted : 09/03/2025 11:53 am
George
(@george-4)
RE: Space prob
To me the pictures look like either a partial clog on the nozzle, or the extruder is not able to push the filament correctly, not a filament issue.
Have you tried to take the extruder appart and clean it? And perhaps take a needle through the nozzle/ do a cold pull.
Posted : 29/04/2025 7:59 am
Bastien
(@bastien)
RE: Space prob
Hello,
Yes i'm trying clean all part of printer, nozzle.
And she does the same problem.
And now i have a another problem. The calibration of Z top faillure.
Thanks for help
Posted : 19/07/2025 5:46 pm
