Prusa Mini - Installed Mosquito Hotend & Now Z-Axis Fail
I just finished installing the Slice Mosquito hotend onto one of my Minis and then re-ran the setup wizard. Running through the self-test, it all looks good except for the Z-axis test. Fails every time. I'm stumped as to what the problem could be. There is no interference preventing full vertical travel, the cables are not restricting movement.
I know on the upgrade instructions on printables.com it mentions that the nozzle sits 1mm lower than stock. Could this be the cause? If so, how do I fix it?
RE: Prusa Mini - Installed Mosquito Hotend & Now Z-Axis Fail
Check my thread on the same issue, https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/failing-z-axis-selftest/
I put the spanner between X-mount and Z-top to take away a few mm of travel distance.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
