Prusa Mini - Installed Mosquito Hotend & Now Z-Axis Fail
jamie.c5
(@jamie-c5)
I just finished installing the Slice Mosquito hotend onto one of my Minis and then re-ran the setup wizard.  Running through the self-test, it all looks good except for the Z-axis test.  Fails every time.  I'm stumped as to what the problem could be.  There is no interference preventing full vertical travel, the cables are not restricting movement.
I know on the upgrade instructions on printables.com it mentions that the nozzle sits 1mm lower than stock.  Could this be the cause?  If so, how do I fix it?
Postato : 06/06/2022 5:08 pm
mrstoned
(@mrstoned)
RE: Prusa Mini - Installed Mosquito Hotend & Now Z-Axis Fail
Check my thread on the same issue, https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/failing-z-axis-selftest/
I put the spanner between X-mount and Z-top to take away a few mm of travel distance.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Postato : 07/06/2022 3:12 pm
