Prusa mini clicking on fast retraction
Andrew B
(@andrew-b-2)
Ive raised the hot end, checked the nozzle, adjusted the tension, opened the hot end and its as clean as a new car, tried to run hotter, when i pull the filament out it doesn't have a blob at the end its nice and pointed. all chat said was to raised the temp and then raise the hot end. please help.
Respondido : 12/09/2020 8:17 pm
Andrew B
(@andrew-b-2)
RE: Prusa mini clicking on fast retraction
bump
i guess no one cares?
Respondido : 14/09/2020 2:03 am
What filament are you using?,
what temperatures are you using, ?
Has it ever printed properly?
do you get filament out of the hot end, when you first  load filament?
have you tried printing with no retraction?
you say the printer is clicking on FAST retraction. what is the printer like on normal retraction?
have you changed anything in slicer, or on the printer?
What have you done to cause fast retraction?
Respondido : 14/09/2020 3:50 am
Andrew B
(@andrew-b-2)
I have not changed any settings from what prusa sets for the printer ..... I do not have any jams it prints great I did replace the hot end tube just because I was I was in there looking for clog I tried all different temps and after 2 different days with chat support I have them stumped they too also think it’s a bearing of some sort just trying to figure out the right one.
Respondido : 14/09/2020 3:53 am
Nick
 Nick
(@nick-17)
I have the same problem on FAST retraction (70 mm/s) set in prusaslicer system valor.
Respondido : 14/09/2020 9:04 am
Nick
 Nick
(@nick-17)
Is good valor Retraction velocity (70 mm/s) set in prusaslicer system valor or high valor ?
Respondido : 27/09/2020 8:31 am
Dimonstar
(@dimonstar)
@andrew-b-2
Have you figured out how to fix this noise?
I think I’m getting exactly same issue.
got all details here and video here:  https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/rattling-sound-while-printing/
Respondido : 03/12/2020 6:25 am
Miembro
I started having this problem and it was soon followed by a jam.  I quit using that filament and it went away.  I have found that this is more common with certain PLAs.  I just don't print them on my mini.
Respondido : 03/12/2020 10:56 am
Miembro
Respondido : 03/12/2020 11:03 am
Dylanb
(@dylanb)
Believe to have a similar situation to yourself and identifiably similar sounds.
Did you ever solve it I too had perfect prints from tests on USB and as soon as I changed over to Prusaslicer settings on fast and sliced my own files I started getting this noise.
Any help would be appreciated
Respondido : 09/04/2021 2:10 pm
