Probe never low enough
Jeremy Makes
(@jeremy-makes)
Had an issue and the printer said it had not been calibrated. I did the calibration again and it always grabs the paper no matter how low I put the probe. I followed that the instructions said to do with the zip tie and even put it closer than that but it always grabs the paper. Any thoughts to what I’m missing?
Napsal : 30/09/2020 12:11 am
RE: Probe never low enough
Contact support by chat.  You may have a bad probe.
Napsal : 30/09/2020 12:17 am
Posted by: @jhopke
A red LED should normally light up on the sensor. As soon as you drive with a metallic object near the sensor head, it should go out. If it doesn't or if the LED doesn't shine at all, I would, as charles already mentioned, contact the Prusachat.
Napsal : 30/09/2020 7:39 am
