Printing lines on all layers
Michel
(@michel-4)
What I have done :
- Adjusted the correct tension of the filament extruder screw.
- Tried other brands of PLA.
- Checked the Bowden tube.
- Decreased and increased nozzle temperature.
- Reduced the printing speed.
- Reduced retraction (1 mm).
- Disassembled and cleaned the extruder system (gears).
- I even changed the extruder motor.
- Changed nozzle for a new one.
- Disassembled, readjusted the hotend and the mini PTFE tube so as not to have a gap.
Cleaned and greased every 200 hours without exception..... I do not know what to do !
Has anyone had this kind of problem before? I print parts for resale and can't do anything with it.
Postato : 18/08/2023 9:51 pm
str0gg
(@str0gg)
RE: Printing lines on all layers
How about image of the problem?
mini+ [bondtech dual drive, revo, reprinted with PA11-CF and ASA] lives in photo tent.
mk4 upgraded to S with mmu3 and gpio (with some parts reprinted) lives in prusa enclosure.
Voron 0 ldo kit with dragon burner and…
Postato : 20/08/2023 7:02 am
Michel
(@michel-4)
Sorry, here it is:
Postato : 20/08/2023 1:23 pm
Michel
(@michel-4)
Here is another image:
Postato : 20/08/2023 1:52 pm
Michel
(@michel-4)
Postato : 20/08/2023 1:54 pm
Michel
(@michel-4)
Here's others images:
Postato : 20/08/2023 7:24 pm
str0gg
(@str0gg)
xyz alignment problem if you have some one to print you
https://www.printables.com/model/61817-prusa-mini-aligner
then recalibrate printer.
Postato : 23/08/2023 9:51 am
Try a different infill pattern and add another top layer or two.
Yours looks like grid with two top layers I would try adaptive cubic and four top layers.
The 'others images' are a different problem, let's deal with them one at a time.
Cheeri,
Postato : 23/08/2023 10:28 am
str0gg
(@str0gg)
take a look on toll object image its no keeping dimensions and lower one its dragging nozzle on the print. Infill has nothing to do with this print.
Postato : 23/08/2023 10:32 am
Michel
(@michel-4)
Ok, "str0gg", I'll try that.
I will begin by printing the "Prusa Mini Aligner". I have a second Prusa Mini which work well. I'll print it out and see what happens.
Thank you very much to you and "Diem", and I'll come back when it's done.
P.s.: I am a French Canadian trying to write good explanations in English, so pardon me if I made some mistakes.... 😉
Postato : 23/08/2023 11:34 am
Michel
(@michel-4)
Ok, I have printed the "Prusa Mini Aligner" and test. Result: No xyz alignment problem.
Still have a problem .... Others suggestions ?
Postato : 23/08/2023 8:11 pm
