New Printer Issues 🙁
Hi Guys
Hope somebody can help
I Got my Prusa Mini yesterday Built it no Problem
But can i get it to do the calibration print 🙁
Had issues with the filament to start with and found it was coming out of the
feeder with ridges so slackened this off
See Pic i just cannot get a consistent calibration print
Can anybody point me in the right direction
Napsal : 03/06/2020 6:54 pm
RE: New Printer Issues 🙁
Your Z offset is too high, lift nozzle up a bit.
Also, just in case, check if the XZ axis is perpendicular to bed, if one side is not higher that the other. X gantry should be as parallel to bed as possible. Release and tighten 3 screws used in assembly to make it square.
Napsal : 04/06/2020 12:35 pm
The smooth PEI steel sheet grabs the filament much better for me than the textured steel sheet.
Napsal : 10/06/2020 8:36 pm
