Mini problem
natrose05
(@natrose05)
Mini problem
I just received my prusa mini and I assembled it but there is no power
Kayla
Opublikowany : 22/08/2020 6:42 am
RE: Mini problem
Log into the online store and contact support via the chat button. They will walk you through troubleshooting.
Opublikowany : 22/08/2020 7:37 am
RE: Mini problem
Posted by: @natrose05
If you have the possibilities, I would check the voltage of the power supply with a multimeter. It should be around 24V. If there is no voltage, probably the power supply is defective. In this case please contact Prusa Chat. This is the fastest way and they will replace the defective part immediately.
Opublikowany : 22/08/2020 12:23 pm
3Delight
(@3delight)
Moderator Moderator
RE: Mini problem
I know it may sound dumb, but, have you checked the fuse in the plug if there is one? Also the fuses on the main electronics board?  It's amazing how they can blow before you even turn it on!
Opublikowany : 22/08/2020 12:31 pm
