Mini+ print problems
Jura
 Jura
(@jura)
Hello,
ia have a lot of problems with printing on my Prus mini. I tryed to clean everything, check tubing, re-grease bearings, check is mini squared, change a nossle, belts tension, all sort of advices from forums..
As you can see on pictures it work horrible. I have it for less than a year now and i did not expect just to brake down like this. It is not used so much, maybe 2 kg of filament in 6-7 months..
Veröffentlicht : 28/05/2022 6:51 am
Let's deal with the obvious things first, there will probably be a couple of small problems left to resolve after this:
Your print-sheet is dirty, clean and degrease it.
Did you run a first layer Z configuration after changing the nozzle?  Run one now and show us the result, *on the print sheet*, I suspect the offset needs to go lower.
Dry your filament.
With power off, move both axes by hand; are they smooth? Does the resistance stay the same over the whole range?
Make your next print this:
https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be printed in Prusament PETG or the spring tension will be wrong.
Veröffentlicht : 28/05/2022 12:12 pm
Jura
 Jura
(@jura)
RE: Mini+ print problems
Hello,
print sheet was dirty only on the photo, i always clean it before print. Also i did all calibrations and it's fine.
It seams that my problem is wet filament. I found one unopened sample and it prints perfectly. So thank you for this tip.
Now i'm in process of finding dryer. Do you have any recomendations?
Veröffentlicht : 29/05/2022 7:23 pm
There are lots of threads here.  I just use a food dehydrator.
Veröffentlicht : 30/05/2022 12:23 am
Chris Laudermilk
(@chris-laudermilk)
One thing that jumps out at me is your live Z is way too high. That needs adjustment too.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Veröffentlicht : 31/05/2022 2:45 pm
