Loose X-axis set screw
I had interesting problem yesterday. 20 minutes into the print X-axis got stuck. One set screw on X-axis pulley got loose. I needed to disassemble whole X and Z axis subassembly to access the screw. I also notice that some of metal on metal screws are loose too. I don't a much so it seems as a big problem to me. It looks like a vibration make metal-on-metal screws loose.
Do you have any recommendation (experience) how to prevent this issue? Loctite Blue 242 maybe? Or maybe Vibra-Tite VC-3?
Thanks, Ondra
Postato : 22/03/2021 6:58 am
RE: Loose X-axis set screw
This was happening to me often and worse over time and it was also causing layer shift and wobbling.
A drop of loctite over the lockscrew fixed it.
Postato : 22/03/2021 3:57 pm
1 persone hanno apprezzato
