How do I eliminate "strings" between multiple print objects?
butchalline
(@butchalline)
I do not know if "stringing" is the correct terminology, but the image below shows the problem.  These model barrels are 12mm tall.
Printing single barrels does eliminate stringing, but I need to do multiple objects, so my questions are:
1. Can stringing be eliminated?  How?
2. How can I remove strings?  I have tried liquid acetone, but that does not work  🙁
Any and all help appreciated
This topic was modified 4 years temu by butchalline
Opublikowany : 07/03/2022 12:45 am
languer
(@languer)
RE: How do I eliminate "strings" between multiple print objects?
The best method to avoid the stringing from object to object is to use Sequential-printing. From your picture, you should be able to take advantage of that.
Opublikowany : 07/03/2022 2:36 am
Your filament is damp, dry it, the surface quality will improve as well.
To remove strings use a heat gun or (careful) a lighter flame.
Opublikowany : 07/03/2022 9:46 am
HermannSW
(@hermannsw)
https://help.prusa3d.com/en/article/stringing-and-oozing_1805
Opublikowany : 07/03/2022 5:12 pm
