Heatbed failure in Mini selftest and heatbed calibration test
Leggo
(@leggo)
I have two Mini-s that I am trying to get running.  When I do the selftest of the components, I get a failure at the very end of the selftest while testing the heatbed.  I have run the self test on both of the Minis simultaneously and have gotten a failure (on the heatbed) on both machines.  What is the chance of that?  I put both machines into factory default mode and have gotten the same results.  I have loaded the most recent firmware (4.3.4 firmware) with the same results.  The error code says to check the heat bed plugin and connections (which I did) and got same result.  What am I missing here?   Is this a firmware issue of these Minis, or are both having some kind of hardware issues?  I purchased one in 2019 and the second in early 2021.  Both have very few hours on them, I would say less than 50 on either of them.
Any suggestions, anyone?
Your help is appreciated.
Veröffentlicht : 20/11/2022 1:46 am
