First Layer Calibration
Stread
(@stread)
I have Problems with the First Layer Calibration. I dont really know what is "good". I made a few Calibration Tests with -1400 -1475 -1500 -1515 and took a Picture of the Square at the End. With -1400 and -1500 I made the Bottom of the Benchy Boat to see the Difference.
At -1515 there are no gaps between the Lines but it looks squished?
Can you look at the the Photos please?
Publié : 17/03/2022 8:04 am
You can go below -1.515.  Please show us the whole calibration print on the print-sheet.
Publié : 17/03/2022 9:12 am
Stread
(@stread)
RE: First Layer Calibration
Ok, here are some more new Calibration Prints.
It is strange that one Print at -1510 is perfect without a hole and another with the same height has many holes?
Publié : 17/03/2022 2:16 pm
Chris Laudermilk
(@chris-laudermilk)
Refer to this page: https://help.prusa3d.com/en/article/first-layer-calibration-mini-mini_229122/
It's supposed to look squished. The 1515 looks close, all the rest of your photos the nozzle is way too high.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Publié : 17/03/2022 2:25 pm
Stread
(@stread)
Thank you.
There is no difference for me at -1515, -1520 or -1525 so I will Stay at -1525 ?
Publié : 17/03/2022 6:59 pm
Lower.
Publié : 18/03/2022 3:25 am
Chris Laudermilk
(@chris-laudermilk)
Yes, lower. You're still getting gaps. Go until it start squeezing little ridges between the lines, then back off until that stops. Using a big, single-layer square helps give time to do this. Either grab a premade one from Prusaprinters or just add a square directly in PrusaSlicer and set it to 0.2 high. Once it looks dialed in you can cancel the print.
Publié : 18/03/2022 3:29 pm
