All my prints have severe stringing
foobar
(@foobar-2)
Whenever I try to print things, I have stringing problems
The above print was multiple miniatures at the same time, as you can see the head had to move large distances with no material, leaving behind a string of material. How often and far the head has to move without printing seems to influence the problem the most.
Single miniatures goes better due to this, but still there's a lot of stringing
Other things I've tried so far:
  • Different filaments
  • Cold pull to clean the hotend/nozzle.
  • Printing at different presets (0.05mm - 0.10mm)
  • Increasing or decreasing retraction
  • Increasing and decreasing the nozzle temperature
And combinations of the above. Some make it slightly better or worse, but I haven't found anything that solves the problem
How can I solve this?
Publié : 30/06/2021 9:13 am
Antonio
(@antonio)
Membre Moderator
RISPONDI: All my prints have severe stringing
If you're printing with PLA, you can try to dry the spool.
if it's PETG, just get over it.
I'm not an expert. Ma parlo anche italiano 😉
Publié : 30/06/2021 10:18 am
foobar
(@foobar-2)
RE: All my prints have severe stringing
It's PLA. I tried printing something with a fresh sealed spool, and it causes the same issue, so it can't be moisture.
Publié : 30/06/2021 6:30 pm
Antonio
(@antonio)
Membre Moderator
i personally use a lighter to burn off the strings and a xacto knife to revome the residue
Publié : 30/06/2021 6:33 pm
Great Dane
(@great-dane)
I have tried to do my first print, the whistle, it started perfectly, and then I left it, but when I came back, it had been all over the place. It looked like a very long curly hair. I just unwrapped the PLA spool, I have the filament sensor, what should I do?
Publié : 01/07/2021 7:35 am
Antonio
(@antonio)
Membre Moderator
Posted by: @great-dane
That's a different issue at all.
Most probably you just have to lower your Live Z value in order to make the print stick better to the bed surface.
Please check the gigantic amount of posts with the same issue
Publié : 01/07/2021 7:47 am
Great Dane
(@great-dane)
@antonio-da-catania
Thanks, that did the trick.
Publié : 01/07/2021 9:28 am
You have no way of knowing how new filament was treated before it got to you and certain manufacturers are notorious for poor treatment of their cheaper filaments...
Dry it.
Publié : 01/07/2021 10:46 am
1 personnes ont aimé
