Top Cover for the MMU3 setup
Scott Clemence
(@scott-clemence)
I didn't like the fact that I have to remove the top just to use the MMU3, kind of defeats the whole "absorbing heat" purpose if you ask me since you would now be letting all the heat out the top.  So, I designed a new top for the CORE One that will keep it covered from the dust and hold some of the heat in.  It's not perfect, but I prefer keeping it covered.  I 3d printed the clips to hold the plexiglass in place.  I'll be posting this design in a bit.
Dieses Thema wurde geändert Vor 10 months von Scott Clemence
Veröffentlicht : 17/07/2025 4:22 pm
David R. Campbell
(@david-r-campbell)
RE: Top Cover for the MMU3 setup
Looks interesting.  Do you have pics of the PTFE penetration of the cover and what you did with the original feed tube?
Veröffentlicht : 17/07/2025 4:31 pm
Scott Clemence
(@scott-clemence)
Currently the back is fully open.  I plan on adding another piece of plexiglass back there that will just have a slot wide enough for the filament selector to move back and forth.
On the original PTFE tube, I just left it alone and routed to the side panel as it was originally.  I still have to switch to non-MMU3 mode once in a while as I print some parts using TPU and the MMU3 doesn't support or feed that flexible filament well at all, it jams every time I've tried using it.
Veröffentlicht : 17/07/2025 4:44 pm
