Instead of COREBOXX or INBXX... how about PrusaExoskeletonBXX ?
Wejn
 Wejn
(@wejn)
I briefly looked at the different filament boxes on printables (e.g. COREBOXX, INBXX) and I'm kinda curious why "nobody" designed one around the "Prusa Exoskeleton" parts (together with some 2020 Alu extrusions)?
I mean as much as I like 3d printing, the multi-day prints that still end up looking similar-but-not-quite are leaving me wanting.
Why not picking up some combo of:
and giving it an internal "skeleton" out of 2020 Alu extrusions, and some custom PC panels?
I mean, I'm the prusa noob here... so, are there any obvious holes in this plan? (yeah, and don't say "cost", because filament + printing time + you babysitting the printer time amounts to more than what the profiles cost 😉 )
Veröffentlicht : 26/02/2026 3:58 pm
Conrad
(@conrad-2)
RE: Instead of COREBOXX or INBXX... how about PrusaExoskeletonBXX ?
A plug for MiniTec here, because I really like their stuff and they have a warehouse near me. https://www.minitecframing.com/
Also, https://www.minitec.de/en/company/locations-worldwide
Veröffentlicht : 26/02/2026 5:53 pm
In my case, I only need space for 4 spools so plan to build the INBXX single which will sit under the printer.
Veröffentlicht : 26/02/2026 7:21 pm
Wejn
 Wejn
(@wejn)
Hm, wonder if using all the "universal profile"s would actually get you the equivalent of INBXX single. 😉
Veröffentlicht : 26/02/2026 7:34 pm
PrintsCharming
(@printscharming)
Hello,  Well as it so happens, I have been working on a design "Core One Cubed" which I used the profile pieces to produce an enclosure that sits atop the Core One and Core One L when I make some adjustments.  I was planning on listing it for sale on Printables.  It is a simple design with novel use of the profile piece to produce the cube and bracket.  It prints easily with only 2 (yes 2!) files.  One file is the enclosure and the second file is the bracket to assemble the cube.  The novel part is that the additional bracket pieces can be snapped into the frame and combined with other designs I am currently working on to manage filament rolls and ptfe tubing for 1, for, or 8 rolls.  I have been working on the design for over 6 weeks and I'm really excited to show it to everyone.  I was planning on listing it in the store for a small fee but I have zero experience with that.  What is others opinion on a reasonable amount to ask for the design? Core One Cubed
Veröffentlicht : 07/03/2026 8:20 pm
PrintsCharming
(@printscharming)
Core One Cubed
Here is another picture of the Cube sitting atop my Core one.
Veröffentlicht : 07/03/2026 8:24 pm
Wejn
 Wejn
(@wejn)
Posted by: @printscharming
Core One Cubed
Correct me if I'm wrong, but this is all printed; this doesn't reuse the metal parts at all?
Veröffentlicht : 11/03/2026 2:44 pm
PrintsCharming
(@printscharming)
Yes, It is all printed.  I used one of the top profile pieces to base it on, and what you see is 8 of the frame parts, held together by 12 of the snap brackets (a total of 2 files).  This is the prototype.
Veröffentlicht : 11/03/2026 8:29 pm
Ghiklm Nopqsrt
(@ghiklm-nopqsrt)
I've been thinking on the same thing, as it it easier to source and 100% aesthetically match CoreOne.
We need a box constructed from 8 horizontal profiles for top and bottom, 4 vertical profiles, 3 similarly shaped sides, one door. Plus some custom internal structure based on whatever you need, thinking of upcoming INDX upgrade for instance.
For top and bottom horizontal profiles, remembering assembly manual, 10. Bottom frame: parts preparation, I'd go with 8 universal profiles and 8 M3x4rT screws. Universal - as they have less holes to patch 😉
For vertical, I'd use as intended 1 front-right-profile + 1 front-left-profile + 2x rear-profile-long . This gives opportunity to have standard door for the front.
In CoreOne, expensive Bottom panel is used to mount bottom frame to the vertical profiles. 2. Base assembly | Prusa Knowledge Base
Instead, here I would rather go with some 2020 aluminum profiles and custom 3d printed parts with matching mounting holes.
For now its just an idea... but seems more interesting/rigid/easy to build to me than a completely 3d printed frame.
Diese r Beitrag wurde geändert Vor 3 weeks 2 mal von Ghiklm Nopqsrt
Please vote for my model in the contest 🙂
Cooler Master: Elite Liquid, External Cover Mod with Mini Display
Veröffentlicht : 09/04/2026 10:33 am
Ghiklm Nopqsrt
(@ghiklm-nopqsrt)
dirty mock up - roughly it can fit up to 12kg plastic 🙂
Veröffentlicht : 09/04/2026 12:41 pm
