HT CORE One: 500c Nozzle and a Fully Automatic, Inputless, Actively Heated, Insulated Chamber
What's everyone thinking about PEEK (Or similar, chamber above 100c) on the CORE One? (Presuming everything functions properly, reliably and safely) Poll is created on Jul 13, 2025
Pagina 3 / 5
MileHigh3Der
(@milehigh3der)
RE: HT CORE One: 500c Nozzle and a Fully Automatic, Inputless, Actively Heated, Insulated Chamber
I’ve been really interested in a high temp option for the Core, and I was hoping that Prusa was going to offer one.  I have a Core kit on order. I’ve just perused the thread, thoughts on starting with a virgin kit?  Would an MMU3 be viable?  High temp CF/GF filled interior and some kind of colored exterior PA or ASA/Acrylic would be interesting.
Postato : 08/08/2025 4:56 pm
Rc
 Rc
(@rc-4)
Posted by: @milehigh3der
I actually also started with the kit! I presume the assembled variant comes with the majority of the tools too. I personally have zero experience and interest in any multi-material unit though, I haven't looked into how I could mod it to work with the optional top panel replacement (The one for filament path strain relief for the particularly brittle filaments), however if you don't do that and the MMU3 doesn't un-enclose the printer I don't see why it wouldn't work! That's because the max chamber temp is still 55c, which is stock, so I'd hope it'd work with those temps! Not too sure where you mean to suggest the "High temp CF/GF filled interior and some kind of colored exterior PA or ASA/Acrylic", but if you mean inside the printer then that's fully up to you to go for! Just note that chamber insulation will need accounting for if you mean adding extra stuff instead of only replacing stock parts. If you mean the interior of the MMU3, I'm sure you could do the exact same of course! Although I see no reason to modify the MMU3 unless you mod the main printer to raise the chamber past 55c, in which case you could likely just modify the mount to include insulation in between the components.
I'm sure it's perfectly doable, and this mod doesn't inherently prohibit it, it would just make it extra challenging if you want both the strain relief on the filament tube, and the MMU3! All presuming the printer stays fully enclosed with it installed of course.
Postato : 09/08/2025 12:30 am
Tim
 Tim
(@tim-21)
Utenti
A little late, but exactly how are you dealing with the integral (PID) tuning for the temp controls??
Postato : 14/09/2025 8:15 pm
Rc
 Rc
(@rc-4)
Posted by: @tim-24
If you mean the heated chamber, it monitors the temp of the pad and makes sure it stays to a currently undecided temperature (Likely just the chamber target temp), and I believe Arduinos can handle PID! And if you mean the hotend, the printer still directly controls both heaters (If you were to also go that route), so standard hotend PID tuning should work! However, even with one 65w heater, autotuning seems to fail beyond ~270c. Manual tuning may be needed! And the chamber will have preset values but if a change is needed it'll have to be manual tuning too.
Postato : 16/09/2025 11:05 am
Sharon
(@sharon-2)
Utenti
just curious exactly how do i flash this to my core one when looking at prusa's guide it says to put the .bbl file in the root of a usb drive however i cant find a .bbl file for this (sorry im not super great at this stuff)
Postato : 26/10/2025 6:59 pm
Gryph
(@gryph)
Utenti
A major issue is the front plexiglass/acrylic panel. Glass temp is just 105 deg with major softening at 80 deg.
Ref: https://bestacrylicsheet.com/acrylic-sheet-performance-temperature-affects/
Postato : 26/10/2025 10:29 pm
Rc
 Rc
(@rc-4)
Posted by: @sharon-2
As of now, it isn't fully finished yet, so I don't have a final firmware file published at the moment! But when I do finish it, you'd just put the file on your drive, make sure it's the only firmware file on there to avoid flashing the wrong one, make sure the appendix bridge on the buddy board is broken to allow flashing of unofficial firmwares, and restart the printer with it plugged in to auto detect it! If it fails to see it, when you see the empty progress bar during boot, hold the knob down for ~1 second, the release, and it should then see the firmware file, then hit "Flash", and when it fails to validate the signature, hit continue/whatever the wording is to proceed anyways! If it won't let you proceed, the appendix isn't broken.
However, I finally have all the parts on the way, so I'm very close to testing assembly and functionality and publishing the final version if all goes well! Really excited to share everything with everyone. Everything should be in in around 2 weeks, as I have to wait on the custom heatblock from PCBWay! Sorry for keeping everyone waiting for ages, I really thought it'd be done by now!
Postato : 03/11/2025 11:31 pm
Rc
 Rc
(@rc-4)
Posted by: @gryph
The chamber doesn't go above the stock 55c, so this won't be an issue! And I'm going to start with making the chamber heater also never go above 55c, instead of upwards of 100c for faster heating like the bed passive heating does, to minimize part replacements and any unexpected behaviors / damages. Even if the acrylic panels could resist higher, the PETG parts within the printer likely can't, so significant modifications would be needed to raise the max chamber temp! Thanks for bringing this up, though!
Postato : 03/11/2025 11:35 pm
The PETG can easily be replaced with Nylon where some flexibility is still needed and polycarbonate otherwise. Same with the door and the side panels. They could be replaced by polycarbonate as well. An insulated chamber that could reach 70C would be awesome as long as the Love Board can handle it. I've been experimenting with printing Delrin but I need a hotter chamber to control warping. If Prusa ever offered (or even a reputable 3rd party) a Core One high temp kit, I would jump on that in a microsecond (assuming it's not ridiculously priced)
The Qidi Plus 4 can hit 350C/65C might start giving it a look.
Postato : 16/11/2025 6:23 pm
Sharon
(@sharon-2)
Utenti
Just letting you know. what I did is I electrical taped all of the major gaps and applied all of the rivets in the plexi panels even when it said I only needed to do a few. along with putting a piece of paper with some tape along the back of the exhaust fans, allowed my chamber to hold steady at about 61-62c
Postato : 16/11/2025 7:41 pm
MileHigh3Der
(@milehigh3der)
https://www.prusa3d.com/product/ht-hotend-upgrade-for-core-one-and-core-one-l/
Not 500C, but 400….
Postato : 19/11/2025 1:22 am
krasovsky
(@krasovsky)
Utenti
Should be by far enough for that printer!
Postato : 22/12/2025 11:37 am
Not 500C, but 400….
Only problem is that it's stupidly expensive for what it is which is just a nickle plated copper block with a HT heating element and thermistor. Will wait for the inevitable 3rd party knockoffs.
Postato : 22/12/2025 3:51 pm
1 persone hanno apprezzato
SciPrint
(@sciprint)
Posted by: @cedric
Here is the standing hook, looks good and works, maybe I should take a look on how PPA print profiles look and adjust a bit in future prints 🙂
Hi Cedric. Great work. Are you using MeltaCollins firmware?
Postato : 08/01/2026 1:23 pm
Cédric
(@cedric)
Posted by: @sciprint
Posted by: @cedric
Nope std printer apart from the single idler wheel mod to handle brittle filament. Seems like the layer adhesion is pretty good, could easily have a 25kg battery hanging in the standing hook. Could be handy with 10-20 degrees more to make it even better 🙂
Postato : 09/01/2026 9:24 am
SciPrint
(@sciprint)
Yes I am wondering if I should wait for the new firmware release or flash custom. Would be interesting to know what the layer strength is at 290C. I have some ppa core to try as is and I should be able to try with a diamond nozzle and new hotend though that would need new firmware. Do I understand you had to have the roof off to print directly? If so perhaps this INBXX system would be a good mod.
Postato : 09/01/2026 12:18 pm
Sorry to be a bit thick here -- what is the "MeltaCollins" firmware? Google came up empty.
Postato : 09/01/2026 12:57 pm
Cédric
(@cedric)
With the single wheel idler arm mod i can use the standard bowden routing, and I can run the roof as standard. I have only tried sirayas PPACF, others might be different, but layer adhesion seems pretty good so far, test it and see what you think 🙂
Postato : 09/01/2026 1:05 pm
SciPrint
(@sciprint)
Haha sorry about that! Its MetaCollins as per the thread here:
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4s-user-mods/print-pei-mk4-high-temp-450-c-mod-is-here/#post-748869
Posted by: @jurgen-7
Postato : 09/01/2026 1:10 pm
Posted by: @cedric
Siraya Tech PPA-CF is the only filament I've had trouble with using the double idler bogie. Probably the stiffest filament I've encountered that can still be printed on a Core One. That said, this stuff is a beast. I used it to print hooks for hanging my bike. I could probably hang my car from it.
Postato : 09/01/2026 7:40 pm
Pagina 3 / 5
