CoreOne Cardboard-Mod [Fun]
I am not sure if I did something wrong while assembling: The whole structure feels wobbly and makes strange noises when running.
Pros:
- Good labeling: The products name is clearly visible and the logo looks good!
- Fun: Is fun to use and easy enough so my 3-year-old daughter can use it.
Cons:
- Spacious: Needs a lot of space (but doubles as a home for my daughter).
- Assembly: Was quite messy and instructions often unclear.
How did you assemble your cardboard?
I really loved the package design and the assembly (apart from the strange decision to use a million different screws)... So I just couldn't stop building and my daughter was eager to help too 😉
RE: CoreOne Cardboard-Mod [Fun]
That's awesome! I did use the cardboard for my XL when I got it, but not as good as you did.
When I bought my XL I needed to make an enclosure for it. The only printer I had big enough to print the parts was my XL. So I built a temporary enclosure. Yes, there is an XL inside there, and yes I had to prop the top open because it was getting too hot inside, above 50°C before I propped open the top.
That was great! A much needed chuckle! Thanks for sharing! Got my mind turning already for when I get my kit…
Prusa MK4S/MMU3
Bambu P2S/AMS2Pro
My cat will be so happy in his new spacious castle when the kit gets here!
Loving the learning curve!
I hope you don't need to return your printer under warranty as the original box and packing are required.
According to the print on the boxes, this was a kit build. I understand that Prusa will supply shipping materials for the assembled printer if a return to base is required; at least that's what they gave me in writing when I asked a couple of months ago. So no harm done by cutting up the kit's parts boxes! 👍
