CoreOne Cardboard-Mod [Fun]
WorstCase
(@worstcase)
Marble run made from cardboard boxes and plastic parts. The boxes are labled "Prusa Core One Assembly Kit"
I am not sure if I did something wrong while assembling: The whole structure feels wobbly and makes strange noises when running.
Pros:
- Good labeling: The products name is clearly visible and the logo looks good!
- Fun: Is fun to use and easy enough so my 3-year-old daughter can use it.
Cons:
- Spacious: Needs a lot of space (but doubles as a home for my daughter).
- Assembly: Was quite messy and instructions often unclear.
How did you assemble your cardboard?
I really loved the package design and the assembly (apart from the strange decision to use a million different screws)... So I just couldn't stop building and my daughter was eager to help too 😉
Napsal : 05/05/2025 12:12 pm
6 lidem se líbí
Brian
(@brian-12)
RE: CoreOne Cardboard-Mod [Fun]
That's awesome! I did use the cardboard for my XL when I got it, but not as good as you did.
When I bought my XL I needed to make an enclosure for it.  The only printer I had big enough to print the parts was my XL.  So I built a temporary enclosure.  Yes, there is an XL inside there, and yes I had to prop the top open because it was getting too hot inside, above 50°C before I propped open the top.
Napsal : 05/05/2025 12:26 pm
2 lidem se líbí
LarGriff
(@largriff)
That was great!  A much needed chuckle!  Thanks for sharing!  Got my mind turning already for when I get my kit…
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Napsal : 05/05/2025 12:43 pm
2 lidem se líbí
GreenPea
(@greenpea)
My cat will be so happy in his new spacious castle when the kit gets here!
Loving the learning curve!
Napsal : 06/05/2025 10:39 am
Chocki
(@chocki)
I hope you don't need to return your printer under warranty as the original box and packing are required.
Napsal : 03/06/2025 12:46 pm
Posted by: @chocki
According to the print on the boxes, this was a kit build. I understand that Prusa will supply shipping materials for the assembled printer if a return to base is required; at least that's what they gave me in writing when I asked  a couple of months ago. So no harm done by cutting up the kit's parts boxes! 👍
Napsal : 03/06/2025 12:58 pm
3 lidem se líbí
