Any recommendations on a Spool Holder mod?
I just don't like the original or the plus spool holders. The filament doesn't seem to feed smoothly, and with a full spool the retraction of initial load will occasionally unspool just enough filament to cause it jump out of the spool. If I don't notice it, when I start printing the filament ends up wrapped around spool holder. This happened to me on the first fresh spool I loaded after installing the new plus spool holder. I am new, and basically only print in PLA and PETG (have done some ASA, TPU, and PCCF), so I don't need anything to fancy, and this will never be a business. Plus I only have about 15-16 cm between the side of the Core One and the wall to I don't have space for anything that sticks out.
Searching Printables shows many mods, but which ones have the forum users actually use, and do they actually work better than the stock for smooth feeding and staying on the spool?
RE: Any recommendations on a Spool Holder mod?
I used this one for a while and it works well: Prusa CORE One Bearing Spool Holder I've since removed it (in fact I don't have any spool holder installed) as I only print from the dryer or a dry box.
