Show your enclosures
Stránka 7 / 8
Owens2303
(@owens2303)
RE: Show your enclosures
I also have not reached above 36 Celsius in my enclosure printing ABS either
Napsal : 22/03/2021 11:35 pm
Robeena Shepherd
(@robeena-shepherd)
I finally got around to releasing everything (I think it's everything) I used to build my enclosure on page 4:
https://www.prusaprinters.org/prints/66830-prusa-mini-enclosure
Napsal : 15/05/2021 12:30 pm
John Doe
(@john-doe-3)
I already twice torn the doors, when doing something with printer (maintenance).
Has someone seen a ikea lack (v1) with roll/pushdown door, just like garages have, but with plexiglass ?
Napsal : 13/06/2021 5:46 am
mark
 mark
(@mark)
@john-doe-3
That's what I did. It's a simple piece of plexiglass that is captured by some clips and slides up and down. It is a little rough, but serviceable.
https://sites.google.com/view/newbieprusaminireview/home
Regards,
Mark
Napsal : 13/06/2021 6:03 am
1 lidem se líbí
John Doe
(@john-doe-3)
@mark-6
Looks nice. But because I have already split the "front" plexiglass, I do not want to go with this. And wife use the top of the Ikea Lack for her things 🙁 ...
Napsal : 13/06/2021 6:50 am
John Doe
(@john-doe-3)
Was thinking something like this... https://www.thingiverse.com/thing:4867501    ... cut plexiglass to 5cm x 44cm , tape together. Print leading rails, basically one vertical, one horizontal and a quarter of circle for each side. If the rotation and stress on plexiglass is high, then either print some extension on the plexiglass or higher diameter of the rails.
Napsal : 13/06/2021 8:42 am
@mark-6
I'm always amazed at the effort people go to in order to give the printer a warm lounge 👍
Napsal : 13/06/2021 9:50 am
@john-doe-3
I have a hard time seeing how acrylic can be bent so much to allow what you're trying to accomplish.
But I understand they the doors always seem to be in the way. Last night I actually started printing parts for this variant of the Lack enclosure: https://www.thingiverse.com/thing:3485510 for my next printer. I like the way you can slide the doors out of the way.
i just printed the first batch of components so I can't vouch for its performance.
Napsal : 13/06/2021 10:00 am
John Doe
(@john-doe-3)
@fuchsr
I was thinking something like this to add.
Napsal : 13/06/2021 11:13 am
@john-doe-3
Very nice design.  You should test it out and add it to the world.
Napsal : 13/06/2021 11:23 am
mark
 mark
(@mark)
Posted by: @karl-herbert
@mark-6
It is not so much for temperature as to exhaust the fumes outside and have the enclosure inside. It's supposed to reach 47 C this week. Inside, the HVAC is set to 25C so cooling is not too expensive.
Regards,
Mark
Napsal : 13/06/2021 12:43 pm
@mark-6
Do you live in a desert (47 degrees C.)? 😊
wbr,
Karl
Napsal : 13/06/2021 1:26 pm
mark
 mark
(@mark)
@karl-herbert
Yes, in the Phoenix, Arizona area. It has reached 50 C. I suppose there are a few warmer places.
Regards,
Mark
Napsal : 13/06/2021 1:35 pm
@mark-6
Then, of course, it makes sense to put the printer in an enclosure and provide a stable climate. 30-35 degrees C. is a good reference value for printing PETG or PLA. For ABS or similar it may be a little more.
happy printing,
Karl
Napsal : 13/06/2021 1:54 pm
obv_
 obv_
(@obv_)
Not really an "enclosure" since there are no walls but this is my printer tower for both 2D and 3D jobs.
Napsal : 29/06/2021 4:04 pm
BrettG
(@brettg)
RE: enjoyable project
A small farm with no live stock
This post was modified před 5 years 2 times by BrettG
Napsal : 27/07/2021 10:37 am
2 lidem se líbí
Minis
Posted by: @brettg
Nice rack of Minis.
Napsal : 27/07/2021 5:39 pm
1 lidem se líbí
Cabinet
Posted by: @brettg
What cabinet did you use to do that?
Napsal : 27/07/2021 5:40 pm
BrettG
(@brettg)
RE: response
Posted by: @cwbullet
Posted by: @brettg
Originally  https://www.ebay.co.uk/itm/312760792774?var=611487887584 then modified. which cable management on the rear for all the power supplies / led lighting, because its mobile on castors allowing me to move around my room and also to get to the rear.
Napsal : 28/07/2021 7:04 am
Wow
I did not recognize it.  You completely transformed it.
Posted by: @brettg
Posted by: @brettg
Napsal : 28/07/2021 9:53 am
1 lidem se líbí
Stránka 7 / 8
