Prusa mini Fysetc clone - log of a journey
Stránka 8 / 9
Rafutti
(@rafutti)
That's what I was going to ask you... I'm using the 5.1.2 corrected by @turro75 to avoid flickering of the original firmware
Napsal : 02/09/2024 11:01 am
I have not had to worry about flickering since they instituted the new versions with input shaping.
Napsal : 02/09/2024 11:40 am
RE: Prusa mini Fysetc clone - log of a journey
Try to downgrade the firmware. My orig. Prusa Mini is running with fw 4.2.1 (tried div. hotends: Revo ok, MK3 E3D ok).
I can't say whether your problem is caused by the firmware, but a test with an older version may provide new insights.
wbr,
Karl
Napsal : 02/09/2024 2:00 pm
Rafutti
(@rafutti)
I have downloaded to firmware 4.4.1 and it gives me the same error...
With cable unplugging from board 12208 and with the cable plugged into board 12206.
Napsal : 02/09/2024 6:46 pm
Rafutti
(@rafutti)
I've finally solved it... I think it was something badly connected. I disassembled everything, I started from scratch and the magic happened.... it worked.
I have no other explanation.
Thank you so much, @Karl-herbert and @cwbullet for the help!!
Napsal : 03/09/2024 7:07 am
happy printing!
Karl
Napsal : 03/09/2024 11:13 am
Turro75
(@turro75)
Hi All,
I updated the patch file to the latest 6.1.2 to enable also the skew correction.
For those who want to build it on his own this is the sequence (I'm on MAC M2):
First of all ensure You are using python3.11 or the build process will fail, on Mac I use the following commands in a terminal:
brew install [email protected]
git clone  https://github.com/prusa3d/Prusa-Firmware-Buddy.git
cd Prusa-Firmware-Buddy
git checkout ffed3df   #this forces version 6.1.2
Now copy the file Fysetc_6.patch to the dir Prusa-Firmware-Buddy
patch -p1 < ./Fysetc_6.patch
python3.11 -m venv .venv
python3.11 utils/build.py --preset mini,mini-en-es,mini-en-cs,mini-en-de,mini-en-es,mini-en-fr,mini-en-it,mini-en-pl,mini-en-jp --build-type release
 You can skip the preset not required by deleting them from the last command.
During the update it erases all the settings so at least take note of the Zoffset value.
  After update during the self calibration test the display got completely messed, neither rebooting fixed it. I switched off, unplugged/replugged the dispaly flat on display side then it reboots and it did not happen anymore....mah....who knows....
I have to say that the printer is now completely free of noise. Just for that I recommend the update.
Napsal : 03/09/2024 10:07 pm
3 lidem se líbí
Rey
 Rey
(@rey)
Recently, the Wi-Fi on my printer has stopped working. I don’t know if something was changed in Prusa Connect and now it no longer works on Fysect versions, or if it’s just mine
Napsal : 14/10/2024 3:39 pm
adp97
(@adp97)
Same issue here. TLS Error and the printer is not able to reach Prusa Connect  (the QR code it shows redirects me to at prusa.io/12401).
My current firmware is 5.1.0+5722.LOCAL, bootloader 2.3.0
I was ok not having internet access, but now my hotend now clogs once every two prints since then. Not sure if it is directly related (probably not) but if I factory reset the board the issue dissapears 😵
Napsal : 14/11/2024 4:24 pm
adp97
(@adp97)
Has anyone checked if the internet error is present on version 6.1.2 on a Fystec board?
Napsal : 14/11/2024 4:27 pm
Turro75
(@turro75)
no probs here, never did before and prusa connect worked at first shot.firmware  6.1.2 shared months ago
Napsal : 14/11/2024 4:48 pm
NightYami
(@nightyami)
Hello Torro, could you link the firmware you build in the comments here?
Thank you very much in advance
Napsal : 15/01/2025 3:37 am
jovo0911
(@jovo0911)
Hello,
has anyone tested the software version 6.20 on a Prusa mini clone or even got it running?
Napsal : 03/02/2025 7:24 pm
Matt Tee
(@matt-tee)
Hi all, just got a used FYSETC mini clone. It overall seems to print pretty well, but never completes a Y axis calibration. Can someone check my calibration video and see if they can determine what’s wrong? Note that I solved the X issue, that was a loose grub screw on the motor
Calibration.
also, the Y motor makes This noise when it hits the stops at the end. Is this normal?
it’s my first 3D printer. Got it for $100cad so I’m not complaining about any of it so far!
It came with the 4.1.1 firmware, and now I have it on 6.3.0, modded for the flashing screen issue. It never passed this calibration in either version.
This post was modified před 1 year by Matt Tee
Napsal : 07/02/2025 6:40 pm
Matt Tee
(@matt-tee)
I’m running the 6.3.0 with the flashing screen fix and it prints fine.
Napsal : 07/02/2025 8:31 pm
Matt Tee
(@matt-tee)
Update to myself: issue was the Y axis belt holder was on backwards, causing it to hit the Y stepper, which in turn reduced the travel and causing the calibration to fail. Now that this is fixed, everything works on the printer, even all the Connect functions! Running 6.2.0 modified for the FYSETC flashing screen issue.
Posted by: @matt-tee
Calibration.
Napsal : 13/02/2025 3:03 am
Adi
 Adi
(@adi-3)
Hi (and for the moderators: hi again).
can you link to this 6.3.0 build? since the 6.2.1 stable build still makes the display flash..
thanks a bunch
Napsal : 01/03/2025 11:13 am
Willdmo
(@willdmo)
Is already anyone here running the stable 6.2.2 release? From my understanding it only needs running the script here and sourcing the correct version from GitHub.
Napsal : 30/03/2025 1:09 pm
I am slowly replacing the parts of the FYSETC with original parts.  So far, it has been drop and go.
Napsal : 30/03/2025 5:17 pm
1 lidem se líbí
Kenyiro34
(@kenyiro34)
hey m8 why this firmware not work filament sensor ?? any possible to work it ?
Posted by: @turro75
Hi All,
Napsal : 16/10/2025 11:40 am
Stránka 8 / 9
