Prusa mini Fysetc clone - log of a journey
Página 3 / 9
Marsh
(@marsh)
RE: Prusa mini Fysetc clone - log of a journey
Solved, just needed to run the install.certificates file
Respondido : 23/05/2021 6:31 am
Marsh
(@marsh)
@poblupuablo
How did you manage to change the hot-end fan PWM? -> in the Configuration_A3ides_2209_MINI.h file, it seems like the extruder_fan is already set at maximum (255). How did you determine that in the clone the hotend fan rpm is only 3000? - I also have the fysetc clone
Esta publicación ha sido modificada el hace 5 years 2 veces por Marsh
Respondido : 23/05/2021 6:38 am
Miembro
@marsh
Can you clarify the certificate file?  What is that?
Respondido : 23/05/2021 3:26 pm
buggyfreak
(@buggyfreak)
@karl-herbert
hi, do i have to cut the appendix for using your custom firmware? i am stuck now. i just upgrade 250mm Y axis board from fystec.
please guide me how to flash your firmware into the mini?
i have plug in your firmware but it doesnt flash.
Respondido : 09/07/2021 1:51 pm
@buggyfreak
I have an original Prusa Mini and after changing the firmware I had to remove the appendix, otherwise the firmware could not be flashed.
https://help.prusa3d.com/en/article/flashing-custom-firmware-mini_14
Respondido : 09/07/2021 6:56 pm
buggyfreak
(@buggyfreak)
@karl-herbert
hi, thanks for replying. how is the step to flash the mini? i saw in youtube, you u need to press the reset button. how many time do i have to press? then when do i press the knob on the LCD? the jumper when do i remove? after reboot or during flashing i remove? becos the staement doesnt state  clearly.
Respondido : 09/07/2021 8:36 pm
buggyfreak
(@buggyfreak)
@karl-herbert
hi,
i cut the appendix, i put jumper. i insert USB. I power ON. i press the rest button and hold. a smoke come out. i switch off. i unplug the USB and insert into my PC. my PC doesnt detect the USB. i change another USB. load the firmware. plug into the mother board. the screen show no USB.
Took out the mother board. look like a chip to USB is burn.
Respondido : 09/07/2021 9:46 pm
Turro75
(@turro75)
@marsh
First page 4th post
Respondido : 14/07/2021 2:13 pm
Turro75
(@turro75)
@buggyfreak
The jumper is needed only if flashing with stlink, You burned the pcb, i think You can still program it by using an stlink v2 (few bucks online), anyway the usb is probably gone
Respondido : 14/07/2021 2:18 pm
@buggyfreak
If you have worked carefully, the USB port should not be damaged when you turn on the printer. However, I think the voltage circuit is broken and the USB port is no longer usable. Thus, flashing the firmware should be a bit more difficult.
https://hackaday.com/2019/12/16/prusa-dares-you-to-break-their-latest-printer/
Here is an interesting discussion:
https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/prusa-changed-main-board-in-mini/
Respondido : 14/07/2021 4:50 pm
1 les gusta
Miembro
updates
Posted by: @buggyfreak
@karl-herbert
hi,
Any updates?
Respondido : 28/07/2021 2:44 am
Urshurak776
(@urshurak776)
Also purchased one....
I saw this thread after purchasing the FYSETC clone.  Just received it today.  Now, I own an Original PrusaMK3S but not a mini.  I really didn't do it to save money either.  I just enjoy this kind of thing.  How cool is it to 3D print a 3d printer?
Anyway, I had some coupons on Aliexpress and got the Fysetc clone for $209 delivered.  Ordered it July 26th and received it around noon Eastern time today.
I unboxed it (box was in great condition) and everything was packed well.  Bearings are by YTP?  I have some better quality bearings, so may play around and see what I'll use.  Full disclosure, after reading reviews, etc. I bought an original Prusa Mini hot end and Bondtech heat break.  I don't even want to mess with the clones from what I gather.  I also bought a dual gear extruder clone, but may hold off on that just for experimental purposes.
Someone mentioned in another thread that the belts are crap.  I agree.  Like rubber bands with bumps.  I have some gates belts that I will use (from my Ender 3 stash.)  The power supply does say Meanwell, but who knows.  The kit overall seems nice.  Not sure how much has changed from those shipped last year to July 2021 this year.  I guess I'll find out!
Respondido : 04/08/2021 7:02 pm
Miembro
FYSETC Clone
There are not bad machines.  They are a tinker's machine.
Respondido : 04/08/2021 7:12 pm
1 les gusta
Menaku
(@menaku)
Firmware Recommendation
Hey there,
I found a custom firmware that allows easy ajustments for your prusa mini clone, bondtech extruder, etc.
It is called Llama Firmware and it is working really well. Here is the github link:
https://github.com/matthewlloyd/Llama-Mini-Firmware
Here are some of its features:
  • Configurable E-steps
  • Set Hotend fan speed
  • Skew compensation
  • PID tuning
I tested version 1.0.5 with my clone and I am very happy with it.
Maybe this firmware is a good choice for you too 😉
Best regards
Respondido : 05/08/2021 5:36 am
1 les gusta
Urshurak776
(@urshurak776)
Mini clone
Thank you!  I will check it out.  Looks perfect.
Respondido : 05/08/2021 10:06 am
Miembro
fork of firmware
Posted by: @menaku
Hey there,
  • Skew compensation
  • PID tuning
Best regards
That is pretty slick.  I will have to try it.
Respondido : 05/08/2021 10:34 am
Turro75
(@turro75)
latest llama with uart6 enabled
For those who want experiment something more of llama this is the firmware.bbf
with uart6 enabled so You can insert an esp8266 preloaded with esp3d in the slot.
Respondido : 05/08/2021 9:05 pm
1 les gusta
Menaku
(@menaku)
RE: latest llama with uart6 enabled
Thanks for the info and your bbf. Adding an ESP32 with ESP3D sounds great!
One question: How did you enable UART6? I have edited the llama firmware a bit further and want to compile it by myself to keep these changes.
Is ESP3D working on your mini clone?
Respondido : 06/08/2021 7:53 am
Turro75
(@turro75)
Uart6 support
In the llama github repo check the pr , there is my pull request which enables the uart6, the bbf is compiled against that pr.
My current setup is:
Esp3d loaded on a esp01s, I enabled the uart ethernet bridge.
Unfortunately the mini firmware does not export the usb as sd card so You cannot use esp3d to print gcode
I connected an rpi0w to the usb A connector, the rpi0w has been tweaked to behave as a usb stick. The folder exported as usb stick is also shared by smb and also used by octoprint as gcode storage. I enabled the uart ethernet plugin so octoprint can talk to the mini through  esp3d. I can also copy gcode to the usb (rpi0w) by network or prusaslicer.
Respondido : 06/08/2021 9:22 am
Miembro
mini
Hopefully, Prusa enables the wireless on the mini soon.  Until then, I am using octoprint
Respondido : 06/08/2021 12:10 pm
Página 3 / 9
