PrintShift - auto-eject prints modification for prusa mini
Antonín Janků
(@antonin-janku)
Good day everyone,
I´ve recently discovered this project, which aims to automatise printing on prusa mini. It ejects prints and thus allows you to print continuosly (almost indefinetly).
https://printshift3d.com/
Has anybody any experience with it? Are there any similar maybe more successfull variations?
What is your opionion on this matter?
I am considering this as a way to be ale to print larger/longer models, and even maybe try to start a mini mini farm(pun intended).
Have a great day, let me know what you think!
Cheeers
Anthony
Napsal : 23/04/2022 7:46 pm
Swiss_Cheese
(@swiss_cheese)
RE: PrintShift - auto-eject prints modification for prusa mini
As often as this happens one might start to think the forums where being seeded.
The Filament Whisperer
Napsal : 24/04/2022 3:50 am
@OP: Sure. If you think this works I have a bridge in New York City to sell you.
Napsal : 24/04/2022 11:55 am
1 lidem se líbí
Antonín Janků
(@antonin-janku)
Bridge? I might be interested
Napsal : 24/04/2022 2:39 pm
Antonín Janků
(@antonin-janku)
Sorry, but I didnt catch your drift? was this being discussed here before, because I didnt find any mention about this topic.
Napsal : 24/04/2022 2:40 pm
John Doe
(@john-doe-3)
I like the idea (seen only the youtube), maybe I will also implement it later on.
But a question, there are also screws in the middle of the bed, which would block the movement to side. Removing from the center would cause ber anomalies
This post was modified před 3 years by John Doe
Napsal : 25/04/2022 6:33 am
Antonín Janků
(@antonin-janku)
There is quite detailed guide on theirs youtube channel and if I am not mistaken the middle screws from bed were removed
Napsal : 25/04/2022 9:08 am
JHenley01
(@jhenley01)
I've actually built this on one of my Minis. It works surprisingly well!
Really the only issue I'm having is with bed leveling and getting a nice first layer across the entire belt. The belt is tensioned so if you have any low spots on the bed the ABL will try to compensate but the belt isn't going to conform to the low spot. This is made somewhat worse by the fact that you have to remove the three center bed supports so the belt can slide through. This makes the bed more likely to sag in the middle. It's not the end of the world and there are ways to work around it.
Definitely an awesome mod! Really love not having to babysit this printer all the time anymore.
Napsal : 03/11/2022 5:37 pm
