Printing my own Prusa Mini
Taylor
(@taylor)
I'm very interested in the idea of self-replication and am looking to print my very own Prusa mini(Maybe even mini +). Prusa releases all print files, is there a kit I can buy for all the nonprintable components?
I Plan on printing the released printed components in some Prusament PETG I have. Would I have to purchase each individual component or would I be able to get a pack that I can't seem to find? If I have to purchase each component is there a possibility of a parts shopping list existing out there?
Opublikowany : 21/02/2022 6:18 am
1 ludzie polubili
LegoYoda
(@legoyoda)
RE: Printing my own Prusa Mini
Following
Opublikowany : 25/03/2022 4:18 am
jsw
 jsw
(@jsw)
You might want to check this out here: https://reprap.org/wiki/Mini_prusa
Opublikowany : 25/03/2022 11:08 am
Oliver-Andre
(@oliver-andre)
Actually on Aliexpress you find complete Prusa Mini about 215€ (and mk3s about 320€) clones. I have build some myself. Actually with some parts not so optimal:
  • - often they use lined heatbreak. You should buy bondtech heatbreak for the mini (and e3d or bimetalic for mk3s)
  • - linear bearings are not best quality. Buy IKO or Mitsumi seperatly
  • - Super Pinda is only available at Prusa shop. Clones use Minda/Pinda2
They work great, like the original.
One advantage if you print parts yourself: Time is not money, like it would be in a print farm. So you can print slow with high quality. Also a bit better material can be worth it. I mostly use ExtrudR Greentec pro now. Look more professional.
Opublikowany : 21/04/2022 2:19 am
KAD370
(@kad370)
I have that kit, like you mentioned. Some parts need to be changed, but overal it is ok printer. Big
I changed belts for Gates GT2 ones, used trianglelab nozzle and heatblock. Added some insulation under bed heater. Rest of it is stock.
Opublikowany : 12/11/2022 12:25 pm
