OctoPi won't boot if plugged in to Mini+
RG Maker
(@rg-maker)
So I have Octoprint Version 1.8.6 running on a Raspberry Pi 3B (using standard OctoPi image).   It all works and can connect to my Prusa Mini fine, print from PrusaSlicer etc.   However if I do a hard reboot of the Pi, the Pi won't boot at all and I think it's getting stuck analysing partitions or something.   If I unplug,  reboot the Pi,  and then reconnect the USB once the web GUI is back up then I can manually connect again from Octoprint successfully.   Has anyone ever encountered this?   No USB key is attached to the Prusa Mini.   Just the Pi3B using the Micro USB port on the Prusa.
octoprint-systeminfo-20230105165137
This topic was modified 3 years temu by RG Maker
Opublikowany : 05/01/2023 4:48 pm
