Mini+ with Hardened Nozzle - Generic settings?
I have a mini+ and have just replaced the stock brass nozzle with a steel hardened nozzle.
I have run first layer caibration again and think i am happy with the offset.
I ran a test print for extrusion, and had layer separation. I was using Pruse Generic PLA settings.
Do i need to increase nozzle temperature?
Veröffentlicht : 11/01/2026 5:34 pm
You might. Steel doesn't conduct heat as well as brass so the two usual options are more heat and slower printing depending on the filament in use.
Try +5° as a start.
Veröffentlicht : 12/01/2026 1:06 pm
