Mini+, Octoprint: SD card mode - is this on a todo list?
pickworthi
(@pickworthi)
Having got my new Mini+ and Octoprint connected, I got all excited when I saw the SD card option, since I though SD card == USB stick in the Mini.
Gave it a go, but nothing happened.
My understanding is that Octoprint is using M20 through M32 gcode commands to implement the SD option.
I found this firmware overview
It contains this block of code, which seems to confirm that the Mini firmware just ignores the commands.
Seems a shame, since it would be a neat way to access the USB stick. Does anyone know if there are plans to implement the commands on the Mini+?
#if ENABLED(SDSUPPORT)
  357         case 20: M20(); break;                                    // M20: List SD card
  358         case 21: M21(); break;                                    // M21: Init SD card
  359         case 22: M22(); break;                                    // M22: Release SD card
  360         case 23: M23(); break;                                    // M23: Select file
  361         case 24: M24(); break;                                    // M24: Start SD print
  362         case 25: M25(); break;                                    // M25: Pause SD print
  363         case 26: M26(); break;                                    // M26: Set SD index
  364         case 27: M27(); break;                                    // M27: Get SD status
  365         case 28: M28(); break;                                    // M28: Start SD write
  366         case 29: M29(); break;                                    // M29: Stop SD write
  367         case 30: M30(); break;                                    // M30 <filename> Delete File
  368         case 32: M32(); break;                                    // M32: Select file and start SD print
Opublikowany : 20/12/2021 7:27 pm
towlerg
(@towlerg)
RE: Mini+, Octoprint: SD card mode - is this on a todo list?
I've probably misunderstood but when you have Octoprint with it's ability to print directly from splicer why would you want to physically transfer gcode?
Opublikowany : 21/12/2021 10:29 am
pickworthi
(@pickworthi)
Posted by: @towlerg
My use case is where I wish to do a local print (i.e. not using Octoprint), and I want to avoid: 1)Removing the USB stick, 2) walking to from the workshop to my house, 3) transferring the gcode file onto the SB stick, 4) Walking back from my house to the workshop, 5) Inserting the USB stick and starting the print.
I'm sure there are others, but: The SD functionality is right there in Octoprint, and the gcodes are defined in Marlin - so missing functionality in Mini+ Marlin implementation in my mind.
Opublikowany : 21/12/2021 12:25 pm
Chris Laudermilk
(@chris-laudermilk)
I'm not getting the need either. If your Octoprint server is accessible from the house then you can just copy the files either by directly dumping them from the slicer, or saving the .gcode file and copying to the web interface. I'm not sure that those commands will actually function with the Pi anyway. Remember that the SD card in the Pi is the main drive; I'm not sure what effect removing it while the Pi is up would have. If you shut down the Pi to swap cards, then you're back to effectively the same SneakerNet scenario as a USB stick, but more fiddly.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Opublikowany : 21/12/2021 3:21 pm
pickworthi
(@pickworthi)
Posted by: @chris-laudermilk
The Octoprint commands for SD refer to the SD card in the *printer*, not in the PI. They are implemented in gcode.
Here is a link to Octioprint FAQ explaining it.
I'm assuming M28 and M29 achieve the equivalent of write to SD from Octoprint, I may be wrong of course.
You can remove the USB stick from the Mini+ at any time (except when it's using it for a Mini+ initiated print of course).
Opublikowany : 21/12/2021 3:32 pm
MysDawg
(@mysdawg)
Posted by: @pickworthi
Once the g-codes have been transferred electronically, I just run them from the app on my phone.
Opublikowany : 21/12/2021 4:18 pm
pickworthi
(@pickworthi)
Posted by: @mysdawg
I've highlighted the difference relevant to this thread.
Opublikowany : 21/12/2021 4:49 pm
3Delight
(@3delight)
Moderator Moderator
The developers rarely come on these forums if at all so you're better of making a feature request over on the Prusa GitHub site here:
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues
Just click on the New issue button on the right and make sure to label it as a Feature Request.
Opublikowany : 21/12/2021 4:54 pm
pickworthi
(@pickworthi)
Posted by: @3delight
Thanks - I guess that is what I was after.
Although, since the M codes are in the reference Marlin firmware, it's more like a missing feature request 🙂
Opublikowany : 21/12/2021 4:56 pm
MysDawg
(@mysdawg)
Fair Enough. I understand what you are after. Please disregard my previous comment. Please let us know if you find the answer that you are seeking.
Opublikowany : 21/12/2021 5:55 pm
pickworthi
(@pickworthi)
Found an existing issue: [FEATURE REQUEST] Treat USB media as SD card for serial control #1076
...and noted developer comment: "fixing this commands is on our to do list."
So, settle back and wait 😉
1 ludzie polubili
towlerg
(@towlerg)
Seems like you've reached some sort of potential solution but I can't shake the feeling that you have misunderstood Octoprint fundamentally. The monitoring, cameras, etc. etc is the icing on the cake, Octoprints  core function is to avoid the inherently slow write of gcode to a printers local SD or even worse the dreaded sneakernet.
Opublikowany : 22/12/2021 11:08 am
pickworthi
(@pickworthi)
Posted by: @towlerg
I think you have fundamentally misunderstood this *one* specific use case, where an operator is local to machine, and wants to use the Mini+ print function, but wants to avoid the hassle of loading the USB stick via manual actions.
I understand Octoprint core functionality perfectly, and am using it in it's current form. Local prints via Mini+ (with Octoprint *disconnected*) are a hassle for me, hence this thread.
And yes, there are other workarounds. This thread is specifically about the Marlin M20 to M32 commands being missing from the Mini+ firmware, as stated in the very first post.
Opublikowany : 22/12/2021 11:19 am
Chris Laudermilk
(@chris-laudermilk)
Ah, ok. It wasn't clear (at least to me) that that's what you were after.
I honestly haven't used the USB stick since getting the OctoPi hooked up. Even with the printer and PC sitting right by each other. So I don't really understand the need, but that doesn't matter.
Opublikowany : 22/12/2021 3:16 pm
towlerg
(@towlerg)
@pickworthi Fair enough, I'll mind my own business.
Opublikowany : 23/12/2021 10:45 am
