.1mm V6 nozzle?
ajemutt
(@ajemutt)
.1mm V6 nozzle?
Hi all!
I'm curious to play around with a .1mm nozzle to see what kind of fine detail I can achieve for some small parts. I got a few brass .1mm nozzles from Amazon, but when I try and change the nozzle size on my mk4, it doesn't have any settings below .25mm
I did see a post that seemed to indicate that it's possible to achieve that setting in the slicer, but I'm a little confused on how that works if the printer complains about not having the specified nozzle.
I'm running firmware v 6.2.4+8909
thx!
AJ
Opublikowany : 13/06/2025 10:54 pm
the nozzle size setting on the printer is just a conscious objector, as far as i know, its there to prompt you that you may have made a mistake. it has no bearing on print settings
you should be able to click through the error message as long as your settings are correct in prusa slicer.
Opublikowany : 13/06/2025 11:10 pm
1 ludzie polubili
