Original Prusa MINI Enclosure - side doors
_KaszpiR_
(@_kaszpir_)
My first ugly iteration
I had to squeeze printer with an enclosure to the closet with limited depth and sliding doors, also I've been using Mini rotated that way for over a year now, so I decided to also adjust the enclosure.
Original Prusa MINI Enclosure - Side Doors Mod:
- raise feet to hide power supply and other things
- rotate enclosure so that left side is now a front face
- 'front door' will be used to feed the filament, as seen on the screen, in the future I need to add magnet coupler there and magnets so it will not separate from the metal wall.
- 'left door' will be used to access the printer as seen on the screen - added handles with magnets and nylon screws with bolts at the bottom for easier door alignment - in general there will be more on this in the future, for now there is a 5mm gap that can be later filled with a foam or something
Probably in the future I will replace side panel with something else because it is quite thin and wobbles, and something like a thicker material would be more useful (similar to front doors)
- make an encasing for the electronics (because it is a nightmare now)
- replace leds with different ones
- add filtration in the future and other 'smart' things.
Respondido : 25/08/2024 10:03 pm
_KaszpiR_
(@_kaszpir_)
https://www.printables.com/model/990504-original-prusa-mini-enclosure-side-panel-magnetic
Respondido : 29/08/2024 9:11 pm
_KaszpiR_
(@_kaszpir_)
Added PTFE magnetic coupler in the place of the normal door handle (instead of the mechanical lock).
https://www.printables.com/model/1000784-prusa-mini-enclosure-door-handle-with-ptfe-magneti
Respondido : 08/09/2024 6:20 pm
_KaszpiR_
(@_kaszpir_)
RE: Original Prusa MINI Enclosure - side doors
Added Temeperature Humidity sensor to make it possible to hang it on the side (the holes are wider).
https://www.printables.com/model/993401-original-prusa-mini-enclosure-side-mount-bracket-f
Respondido : 08/09/2024 6:24 pm
_KaszpiR_
(@_kaszpir_)
Added longer LCD cable and mounted it to the side of the enclosure
Prusa Mini Enclosure LCD Side Mount Frame.
https://www.printables.com/model/1040017-prusa-mini-enclosure-lcd-side-mount-frame
Respondido : 14/10/2024 10:23 pm
