Enclosure Bowden Quick Release
I was trying to find a way to quickly manage runouts when using the enclosure mounted spool holder through the Bowden tube.I found a great model idea that did this but didn’t use the same size fittings. I remixed that to be compatible with the equipment in the enclosure. Additionally, it helps with quickly switching between using the tube or not using the tube similar to the mk3 before the enclosure. I hope this is helpful to others.
https://www.printables.com/model/464325-magnetic-reverse-bowden-adapter-mk3s-for-original-
Ce sujet a été modifié il y a 3 years par ablackbu
Publié : 28/04/2023 6:16 pm
