Door Stops
My enclosure table is likely ever so slightly unlevel, which causes the left door of my enclosure to swing partway shut. This is annoying enough that I decided to model and print a door stop, and I figured I'd share it in case anyone else has the same problem.
https://www.printables.com/model/281123-original-prusa-enclosure-door-stop
Opublikowany : 22/09/2022 3:45 pm
RE: Door Stops
Nice addition. You could shim your table to make it level.
Opublikowany : 23/09/2022 9:59 am
