Disconnects for PSU and Panic Cables
Spring Hollow
(@spring-hollow)
Is there any reason not to use Deutsch DT Style connectors as disconnects for the cables?
Napsal : 16/02/2026 6:17 pm
RE: Disconnects for PSU and Panic Cables
Deutsch DT connectors seem to be rated at 13Amps,
Mk3, Mk4 printers have 250 watt power supplies, at 24 volts that is a little over 10 amps,
the power is shared between two pairs of power cables, so you should be OK.
I am not sure what power supplies other printers use...
I used XT60 connectors for My power leads
Power panic doesn't need a high current, so any polarised connector will do,
Don't forget to connect the earth wire, if your printer has one.
My Mk4 has earth wires My Mk3's do not
Napsal : 17/02/2026 11:07 am
Spring Hollow
(@spring-hollow)
Thanks everyone.  The XT60 connectors seem very nice - I have not seen those before.
Napsal : 17/02/2026 4:59 pm
