Zits or Blobs since I migratred from 2.3 to 2.4
Pieter
(@pieter-2)
Since I've migrated from prusaslicer 2.3 to 2.4 I have little blobs on my outer walls.
My printer is a BIQU B1 with a bowden extruder.
Retraction Length = 8mm,
Z-hop =  0.4mm,
retraction speed = 85mm/s,
Deretractionspeed = 40mm/s,
retract on layerchange = set,
Wipe on retract = set,
retract on wipe = 70%.
The object in the cipure is prited wit 205 deg and 40 mm/sec speed.
Hope someone has some pointers for me to improve the quality of my prints.
regards Pieter.
Opublikowany : 14/04/2022 12:51 pm
Bratinm
(@bratinm)
RE: Zits or Blobs since I migratred from 2.3 to 2.4
I just got a BIQU B1 yesterday, can you please share your profile? We can help each other to fine-tune the profile.
Opublikowany : 19/05/2022 5:59 pm
Pieter
(@pieter-2)
My_B1_config
Opublikowany : 19/05/2022 6:09 pm
Pieter
(@pieter-2)
I've posted the config as a txt file you have to rename it to an ini file and then import it by Ctrl + L
succes.
Opublikowany : 19/05/2022 6:12 pm
