Wipe distance?
What are the wipe distance? Is it same as retraction length? If it is, if i set retract 60% before wipe will that mean it wipes 0.4mm if i have 1mm retraction?
Postato : 03/11/2023 9:41 am
RE: Wipe distance?
The retraction length is typically specified in millimeters, while wipe distance is usually defined as a percentage of the nozzle's diameter or a fixed value.
Postato : 23/11/2023 8:12 am
