Wipe distance?
What are the wipe distance? Is it same as retraction length? If it is, if i set retract 60% before wipe will that mean it wipes 0.4mm if i have 1mm retraction?
Veröffentlicht : 03/11/2023 9:41 am
RE: Wipe distance?
The retraction length is typically specified in millimeters, while wipe distance is usually defined as a percentage of the nozzle's diameter or a fixed value.
Veröffentlicht : 23/11/2023 8:12 am
RE: Wipe distance?
Wipe distance and retraction length are different. Wipe distance refers to the nozzle's movement while retracting. If set to retract 60% before wipe, it wipes 0.4mm with 1mm retraction.
Veröffentlicht : 22/10/2024 7:49 am
