Windows 11 weirdness?
I decided to bite the bullet and try Windows 11 again and see if things were more stable now. The first thing I happened to do was open PrusaSlicer and noticed some weird things. The UI was basically the same, but things were a little different, which I first chalked up to perhaps I was using an older version of the slicer. Then I went and checked the version and it was 2.6.1, just like before. And then in the print settings, I noticed that it was pretty different:
windows 11 version:
Any thoughts on what is going on here?
windows 11 version:Any thoughts on what is going on here?
im running on 2 machines both windows 11 and i get this on windows 11 are you running 64 bit or 32 bit
RE: Windows 11 weirdness?
Both are 64 bit.
