Why is the Slicer making bridges stating with longest span
MasterCATZ
(@mastercatz)
model needs flipping 180 deg Y  90 deg Z everytime I am in cad I seem to make things upsidedown ...
their is a 40mm span it could be doing but it keeps opting to try making 200mm spans ? 0.3mm first layer
layers 130 @ 0.1  82 @ 0.2  66 @ 0.3 etc
it even made a support it could have been using
https://drive.google.com/drive/folders/1UI_Dl-PTnfr0aiKyFiLz1BeF4piPtPhm
PrusaSlicer-2.2.0+linux-x64-202003211856.AppImage
This topic was modified 6 years temu by MasterCATZ
Opublikowany : 20/10/2020 12:53 am
RE: Why is the Slicer making bridges stating with longest span
Hi Mastercatz,
Have you tried changing the Bridging Angle?
90 degrees may be good.
Regards Joan
Opublikowany : 20/10/2020 1:19 am
1 ludzie polubili
MasterCATZ
(@mastercatz)
@joantabb
thanks setting to 45 helped
I ended up making my own supports however , just found it odd that the code would be trying to go long when shorter possilities were avaialble
Opublikowany : 20/10/2020 10:32 pm
Slicers are amazing, but not infallible.
Lol...
Joan
Opublikowany : 20/10/2020 11:39 pm
